Date/Time: Sun, 19 May 2024 05:24:12 +0000
SIerra Chart locks up every time I do a replay chart to test my ACSIL custom study
View Count: 1402
[2015-08-28 20:34:19] |
hung4me - Posts: 8 |
I can run my ACSIL study fine in bar-based back test or in real time sim or live but every time I run a replay back test, Sierra Chart locks up and become unresponsive. Below describes my settings and environment. I have read the help sections on manual replay of charts for trading systems and think I am doing everything right. Please help! 2 charts in chartbook - a 5m ES and 1m ES. The 5m chart has 2 studies overlayed onto the 1m chart Have tried with 5m and 1m having exact same number of days and with 5m having more days of data global settings --> general settings, I have "use controlled order chart updating" checked global settings --> data/trade service settings, I have "intraday Data Storage Time Unit" set to 1 tick Trade --> autotrade enabled Trade --> trade simulation mode on Replay steps. 1. Load chart and enable study 2. Disconnect from server 3. Scroll to beginning of day on 1m chart 4. Open chart replay menu 5. Set chart replay to "Accurate Trading System Back Test Mode" 6. Check "For all Charts in Chartbook" 7. Set replay speed to 240 (it locks up even when set to 1) 8. Hit play 9. Hit OK and set "enter processing Step in seconds" to 15 (default of 60 locks up also) 10. SC opens popup window "loading... 0% ESU5 Click to cancel" and locks up. has to be killed in Windows. |
[2015-08-28 21:15:22] |
Only open these two charts in Sierra Chart and nothing else. Remove all the studies from the charts. No studies all. Do you still notice this by performing the steps that you do: 10. SC opens popup window "loading... 0% ESU5 Click to cancel" and locks up. has to be killed in Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-02 16:54:26] |
It works OK without studies. I am sure it is something in my ACSIL code and will try and do some debugging. Thanks for the quick response
