Date/Time: Sun, 19 May 2024 11:05:31 +0000
Using Multiple Computers
View Count: 971
[2015-08-28 19:39:08] |
ripsdips - Posts: 143 |
I'm using 2 PC's at the same location, from the same IP. Do I have to purchase an additional SC instance if I'm running both computers simultaneously?
[2015-08-28 19:42:48] |
No you do not. Your account allows you to use Sierra Chart on three systems.
