Date/Time: Thu, 02 May 2024 08:12:51 +0000
[Locked] - Adjusting user drawn volume profile
View Count: 858
[2015-08-28 08:07:32] |
Zdislav - Posts: 73 |
When I use the volume profile drawing tool on chart, it works fine. But when I try to adjust it draging the RIGHT border, the profile does not change. Only dragging the LEFT border afterwards trigers the redrawing of the profile according to adjustments. Not a big deal but a bit annoying... It was in v1287, now I downloaded v1288 prerelease and it is the same.
[2015-08-28 11:50:13] |
We will have this problem solved by Monday. For now select Chart >> Recalculate after adjusting the right side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-28 19:00:21] |
That's what I do... Thank you very much. I really appreciate these quick updates. Keep up the good work, SC-guys! :-) |
