Date/Time: Tue, 07 May 2024 14:52:46 +0000
Custom formulas
View Count: 1147
[2015-08-28 06:19:06] |
User713273 - Posts: 409 |
I need a ouput of a custom formula to be the input of a custom formula in the same row. Getting a bunch of #REF errors, what is the case behind this. Thx |
[2015-08-28 14:41:03] |
http://www.sierrachart.com/image.php?l=1440772711500.png This might clarify, k and l columns are referenced above. |
[2015-08-28 18:15:06] |
Update Sierra Chart to the latest release. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Here is the documentation for the Reference error: https://www.sierrachart.com/index.php?page=doc/doc_Spreadsheets.html#SpreadsheetErrorCodes Updating to the latest release should solve the problem as long as the formula is valid. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
