Date/Time: Thu, 02 May 2024 19:00:08 +0000
TD Ameritrade Trading Futures
View Count: 1992
[2015-08-28 00:49:38] |
Bergsteiger - Posts: 2 |
Good Day, Can you trade futures from a TD Ameritrade account with using the data feed from Sierra Chart? Note: Futures trading and market data is not supported when using TD Ameritrade because it is not supported by the TD Ameritrade API that Sierra Chart uses to connect to the TD Ameritrade systems. However, it is possible to use a separately paid for futures data feed for CME/CBOT/NYMEX/COMEX futures when using the TD Ameritrade trading service. For instructions to use this data feed, refer to Sierra Chart Real-Time and Historical Exchange Data Feed. Thanks. Tim |
[2015-08-28 01:00:28] |
You cannot submit futures orders directly from Sierra Chart to a TD Ameritrade account, if that is what you are asking. But you can receive futures data from the Sierra Chart Real-Time and Historical Exchange Data Feed when connected to Ameritrade. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-28 01:00:51
[2015-08-28 01:05:08] |
From the question that was submitted I was indeed asking if we can submit futures orders directly to TD Ameritrade for execution. Thanks for the reply. Cheers Berg |
