Date/Time: Tue, 07 May 2024 23:33:56 +0000
Nice Feature: New Control Bar and Compact Tool Values Window
View Count: 734
[2015-08-27 07:31:07] |
Kiwi - Posts: 374 |
I instantly liked the new Control Bar although I struggled to like the CTVW ... it kept appearing in the wrong place and was a bit of a nuisance. Then I followed your helps and read the instructions. http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData It's now a tidy horizontal structure and it sits in the blank space at the end of the Control Bar. Easy to find and easy to read. Excellent thanks. Date Time Of Last Edit: 2015-08-27 07:33:10
[2015-08-27 08:03:12] |
Sounds like most people want to not save the position of the Compact Tool Values Window for each chart. So that option should be unchecked. We will make that the default going forward. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
