Date/Time: Fri, 03 May 2024 04:00:25 +0000
1287 - release note related question
View Count: 793
[2015-08-26 23:12:23] |
ejtrader - Posts: 688 |
SC Team - you have made the following release note for 1287. Wondering if this would require any changes to the VWAP based study as well or this is transparent and no changes needs to be made which are based on s_VolumeAtPriceV2 structure? Thanks Significant performance improvements with the Volume by Price study have been made when using single Volume Profiles like manually drawn profiles. |
[2015-08-26 23:20:53] |
The change does not involve the underlying Volume at Price data.
