Date/Time: Mon, 06 May 2024 01:01:34 +0000
color bar based on alert condition arrows
View Count: 2629
[2015-08-26 22:36:47] |
User170575 - Posts: 221 |
Hi, using the "color bar based on alert condition" how do I get the arrows placed under the chart bars instead of at the bottom of the chart? Many thanks |
[2015-08-26 23:59:01] |
Sawtooth - Posts: 3993 |
Set 'Output When Condition True' to 'Use Input Data', then set 'Input Data' to 'Low'.
[2015-08-27 10:10:03] |
This is actually explained in detail in this section here for the study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
