Date/Time: Mon, 29 Apr 2024 22:48:37 +0000
New Daily Bar at New Session
View Count: 889
[2015-08-26 14:21:42] |
infpz - Posts: 826 |
Assuming you're trading products that open at 5 PM CT, is there a way to get a new daily bar starting at 5 PM without following these steps for each individual symbol? http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.6 For the sake of this example, I have a customer who trades 10-15 markets right on the reopen at 5 PM and he would like to be able to see a new bar automatically when he logs in at 5 PM. |
[2015-08-26 17:13:10] |
No. Those instructions must be followed and also they need to be running the latest prerelease due to some recent changes to that functionality.
[2015-08-27 12:26:05] |
OK. Would setting the chart to a 1440 minute chart with the appropriate start/end times be a good workaround?
[2015-08-27 17:50:26] |
Yes it will. Instructions for this can be found on this page: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
