Date/Time: Thu, 02 May 2024 17:47:24 +0000
Turn Vertical line Off When Using Crosshair Tool
View Count: 825
[2015-08-26 02:05:49] |
absorrel4 - Posts: 92 |
Is there a way to turn off the vertical line when using the crosshair tool?....or another tool that only shows the horizontal line similar to when using the crosshair tool?
[2015-08-26 05:47:38] |
You can only remove the Vertical and Horizontal lines with the Chart Values tool. Not one or the other.
