Date/Time: Fri, 03 May 2024 08:39:35 +0000
Download Current Version
View Count: 712
[2015-08-26 00:44:22] |
guyl - Posts: 58 |
I got a new message to upgrade my system but I can't remember whether to go with the new spreadsheet or the old spreadsheet version. Can you tell me the difference please?
[2015-08-26 01:03:25] |
If you are not sure we recommend using New Spreadsheets.
