Date/Time: Tue, 07 May 2024 08:49:19 +0000
rename a chart
View Count: 1788
[2015-08-25 15:56:11] |
User20450 - Posts: 330 |
how do i rename a chart , not a chart book
[2015-08-25 17:45:50] |
What do you mean by renaming a chart? Do you mean changing the symbol of the chart?
[2015-08-25 17:53:00] |
JUST THE name on the chart , on lower tab says esu5 , can i rename it Es 60 min profile - example
[2015-08-25 19:45:29] |
This can be done by following the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#ChangingTabNames Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
