Date/Time: Fri, 03 May 2024 07:03:43 +0000
detach chartbook
View Count: 885
[2015-08-25 12:48:09] |
User20450 - Posts: 330 |
can a chartbook be detached and still have the charts tabs under it ? if not would make great feature for multiple monitor setups , thanks
[2015-08-25 17:31:05] |
Only individual charts and Spreadsheets can be detached. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
