Date/Time: Thu, 16 May 2024 02:22:07 +0000
Stops on CME Submitted through CQG
View Count: 724
[2015-08-24 22:27:52] |
User56866 - Posts: 28 |
Hi As you know the CME does not support stop market orders instead they have "stops with protection" essentially a Stop Limit order. When Sierra submits a stop order through a CQG feed to the CME do you know if CQG is simulating this stop on their servers or if they are passing through a native Stop with Proctecion order on the CME? Best regards, Ben |
[2015-08-24 23:01:06] |
You need to ask CQG this question. However, we believe that CQG is sending it to the exchange.
