Date/Time: Mon, 06 May 2024 03:59:27 +0000
Payment question
View Count: 774
[2015-08-24 16:00:33] |
bookert4 - Posts: 56 |
Hello Support, At this time I am using the TS4 trading service. I am not using Sierras data. Can I temporarily disable that data feed for now ? Also, will my TS4 data be sufficient? Thank you |
[2015-08-24 17:36:02] |
What does TS4 stand for? We have no idea what that is. To disable the Sierra Chart Exchange Data Feed, go to this page: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures And Deactivate the data feed. You will also first need to deactivate the exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-24 17:43:25] |
Sorry correction. The CTS4 platform. I am currently using this platform which has a market datafeed. Can I deactivate the Sierra date feed without effecting data from the CTS4 platform ? I am trying to keep costs down while I am on the CTS4 temporarily. I do know how to deactivate. Thank you |
[2015-08-24 18:42:31] |
Yes you can definitely deactivate the Sierra Chart Exchange Data Feed because the CTS T4 trading platform service does provide market data. But you might have to activate the exchanges in the CTS T4 system that you need data for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
