Date/Time: Thu, 02 May 2024 23:35:59 +0000
the unvisible last bar after double click the scale on the right side of the chart
View Count: 794
[2015-08-24 07:50:29] |
User573855 - Posts: 10 |
Hello, I donĀ“t see last bar after double click the scale on the right side of the chart. Constant Range Auto-Center have been set from me. Exist any another setting for Constant Range Auto-Center for comfortable using of number bars?
[2015-08-24 07:56:48] |
After you reset the scale on the right side of the chart by double-clicking on the scale, provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-24 08:16:55
[2015-08-24 08:14:35] |
However, after reading your question again it sounds as though you should be using an Automatic scale and using Interactive Scale Range and Move. For more information, refer to: https://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#Scaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-24 08:21:40
[2015-08-24 08:22:51] |
Refer to the prior post for additional information. We had first asked for a chart image because we needed to have an understanding of what you are asking. It was not clear for us. What may be clear for you, is not clear for us because we have no idea what you are seeing and exactly what you are expecting to see and why. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-24 08:23:18
