Date/Time: Mon, 06 May 2024 20:40:41 +0000
ToolConfig labels not updating
View Count: 1046
[2015-08-24 01:19:02] |
User742717 Mike - Posts: 86 |
Hello, On a line (trend) config, I save the different TC labels, I can confirm it works because the tool tip on the TC1-ect shows the correct labels. But on the line, the label doesn't update. Also, the label doesn't appear at all, ie Rect has no label visable. Cheers Mike. |
[2015-08-24 01:49:43] |
This is not supported and there are definitely no plans to support this.
[2015-08-24 02:08:13] |
For more information about Labels >> Copy Config Name to Text, refer to: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html&CAID=#CommonToolConfigSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-24 07:15:13] |
Strange, it works on TC3,5,6 but not the rest. Here's an unlisted video: https://www.youtube.com/watch?v=Zi6JEo8Sp10 It's not critical for me, but a nice to have. |
[2015-08-24 08:38:16] |
And for Line Tool Configurations 1, 2, 4, how do you have this set: Labels >> Copy Config Name to Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-24 10:21:10] |
Hi, Thanks for the help and you are correct they are ticked, I can save the ticked configs to the other configs :) I don't know how they got ticked/unticked because all label options (at least under the trend line tool) are disabled except for Opaque label background. Do you know how or where it gets ticked/unticked? Cheers Mike. |
[2015-08-25 08:34:47] |
We are not clear about your response. Refer to this section here about Drawing Tool Configurations: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-25 13:49:16] |
The trend lines tool config, Label tab has "Copy config name to Text" greyed out. So how can it be changed? |
[2015-08-25 17:31:59] |
This can only be changed through the Drawing Tool Configuration as documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawingToolConfiguration Not through Chart Drawing Properties. The documentation we linked to in post #3 states this very clearly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-25 17:33:16
