Date/Time: Mon, 20 May 2024 00:36:49 +0000
Volume Profiles & drawings added by UseTool - displaying issue
View Count: 934
[2015-08-23 12:58:04] |
sampater - Posts: 243 |
SC, I have the Volume By Price study that displaying the Volume Profiles. Next in an order is my custom study that displaying drawings added by UseTool. And these drawings are drawing underneath the Volume Profiles. The Subgraph's drawings (e.g. Draw Style: Line) are drawing above the Volume Profiles, compatibly to the order of applied studies. Can you fix it that drawings added by UseTool would be displaying above the Volume Profiles, like the Subgraph's drawings if the Volume By Price study is before a study with drawings added by UseTool? Analogic issue is with the Peaks & Valleys lines that are drawing above drawings added by UseTool but underneath the Subgraph's drawings. Thanks Marek |
[2015-08-25 08:31:15] |
You can already control this: https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html#DrawUnderneathMainGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-25 20:14:06] |
I know this feature. But if i set Tool.DrawUnderneathMainGraph = false then my chart drawings are drawing above the main price graph and they hide the main price graph too much. And if i set Tool.DrawUnderneathMainGraph = true then my chart drawings are drawing underneath the Volume Profiles (and the Peaks & Valleys lines) and my chart drawings are hidden by them too much. Maybe another way to fix this issue could be added new input in the Volume By Price study: "Draw Chart Drawing underneath Volume Profiles" which will be independent of the Tool.DrawUnderneathMainGraph. Or could be added new member for the s_UseTool::DrawUnderneathVolumeProfiles I use this chart drawings to draw the PoC, VAH, VAL lines and many other items from a few higher time frames in the chart that display the Volume Profiles, which hide this chart drawings. And if i set the Tool.DrawUnderneathMainGraph = false then the main price graph is poorly visible. Thanks Marek Date Time Of Last Edit: 2015-08-25 20:14:43
[2015-08-25 20:46:19] |
This is not something we are willing to support right now. It is too involved. Chart Drawings can be drawn either above the graphs in the chart or below. And that can be independently controlled per Chart Drawing. There is no way to layer them among the different graphs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-25 20:47:06
