Date/Time: Sun, 05 May 2024 13:20:55 +0000
The old tool bar
View Count: 769
[2015-08-21 23:05:56] |
Ed Meckelborg - Posts: 71 |
I tried to download the old 1269 S.Charts The link that you gave me does not work. How do I get the old S.C. back. I'm hoping to get the tool bar back that gives me the high, low, close, time, etc. I think that 1269 did that If you want to go back to 1269 use this link: https://www.sierrachart.com/downloads/1269SierraChartSetup.exe |
[2015-08-22 01:09:19] |
This link works for us. What happens when you click on this link? What web browser are you using?
