Date/Time: Sat, 04 May 2024 19:35:59 +0000
C++ CONVERSION TO SIERRA CHARTS
View Count: 1355
[2015-08-21 13:02:55] |
User28317 - Posts: 147 |
AFTER 3 YEARS I GOT MY PROCESS WRITTEN BY A PROGRAMMER IN C++. HE USES A COMPETITOR TO SIERRA CHARTS. I WOULD PREFER TO STAY WITH THIS PLATFORM RATHER THAN SWITCH. DO YOU HAVE SOMEONE THAT CAN MAKE MY PROGRAM WORK ON SIERRA CHARTS?
[2015-08-21 17:24:28] |
Why not have them do this programming? Sierra Chart does use C++ as well. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html You can also refer to this section here: https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-21 23:45:03] |
THEY TELL ME THEY DON'T WORK WITH SIERRA CHARTS OR CHARTING IN GENERAL. DOESN'T MAKE SENSE TO ME.
[2015-08-22 07:22:21] |
It does not make sense to us either. A good programmer should be able to work with different languages and APIs. However in this case Sierra Chart does already use C++. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
