Date/Time: Thu, 02 May 2024 21:36:12 +0000
[Locked] - Daily Chart FDax
View Count: 910
[2015-08-21 06:13:26] |
User297539 - Posts: 55 |
Hallo SC, habe unterschiedliche Last Price im Chart 1H und Daily! Habe schon mit ( Delete and Download Data) probiert aber ohne Veränderung!
21-08-2015 07-47-12.jpg / V - Attached On 2015-08-21 06:12:20 UTC - Size: 519.93 KB - 323 views Attachment Deleted. |
[2015-08-21 09:02:07] |
In regards to a problem with the historical Daily chart, refer to this help topic: No Historical Chart or Blank Chart | Historical Chart Not Updating | Missing Historical Chart Data If there is a problem with missing data in the Intraday chart, refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-23 22:51:44] |
Hallo SC, Die angegebenen Vorschläge haben mir nicht weiter geholfen! Ich habe das Problem nur bei den Historischen Daten Dly / We / Mon, ab ca.18:00 Uhr werden keine Daten geliefert, Intraday ist alles ok. Wie kann ich das Problem beheben? |
24-08-2015 00-10-28.jpg / V - Attached On 2015-08-23 22:50:24 UTC - Size: 960.25 KB - 329 views |
[2015-08-24 03:20:50] |
This is explained in this section here: https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.10 Daily, Weekly and Monthly bars always will show the official exchange settlement price at the close. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-26 12:24:39] |
Hallo, Habe heute wieder das Problem. Im Daily Chart last Price ist 10162,5 und Intraday 9825, ich habe einen Bild im Anhang zum Vergleichen, das Markierter Bereich im 1H Chart wird im Dly Chart nicht angezeigt. Ich habe mich an AMP Gewendet und die haben noch keine Lösung für mich. Haben Sie noch Vorschläge wie das zu lösen ist? |
26-08-2015 13-55-04.jpg / V - Attached On 2015-08-26 12:23:59 UTC - Size: 389.5 KB - 293 views |
[2015-08-26 18:05:05] |
Refer to section 12.10 here: https://www.sierrachart.com/index.php?page=doc/helpdetails12.html#12.10 This is at the end of the page. This support request is now closed and we do not have any further information to provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
