Date/Time: Tue, 30 Apr 2024 09:14:59 +0000
alert condition including OR statement
View Count: 680
[2015-08-21 02:32:56] |
User144295 - Posts: 59 |
Hi Sierra Chart team, I reviewed alert conditions on this thread but I still did not figure out how can I create following alert. Would you please me to check correct syntax? It is relating to same study ID. i.e. ID4 But there are two SG elements SG12 and SG22. And I would like to make condition that if one of them is > 0 then make sound. I tried to come up with this but it is not acceptable by Sierra. SG12>0 OR SG22>0 Thank you very much for help |
[2015-08-21 04:07:36] |
Use this: OR (SG12>0 , SG22>0) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
