Date/Time: Fri, 03 May 2024 04:20:25 +0000
[User Discussion] - Apple Platform
View Count: 1964
[2015-08-20 14:55:31] |
gmorgan111 - Posts: 121 |
A simple question does Sierra Charts run on the Apple Platform Thanks |
[2015-08-20 17:14:27] |
No it does not.
[2015-08-20 17:30:23] |
SgtJ - Posts: 154 |
I don't know much about ios, but people that run windows software on a mac using parallels, or other virtual environments say they often run more efficiently then in windows based on cpu usage.
[2015-08-21 04:14:53] |
Acro - Posts: 436 |
I have always used Sierra inside Parallels. Currently I use Parallels 10, Windows 8 and the latest release of Sierra (1282 with new spreadsheets) and can confirm that all runs fine with really low CPU usage. However, I don't like the business model being instituted by Parallels where they are trying to turn it into a subscription based service penalising users who use more RAM and more virtual CPUs. My two cents |
