Date/Time: Sun, 28 Apr 2024 00:23:15 +0000
OEC not intraday data for Dec Cotton
View Count: 1606
[2013-06-12 23:14:36] |
Paul.M - Posts: 113 |
OEC no intraday data for Dec Cotton
Date Time Of Last Edit: 2013-06-18 10:27:40
[2013-06-18 10:29:52] |
still no intraday history
[2013-06-18 10:30:05] |
you plan to answer this ?
[2013-06-18 10:43:05] |
We did work on this at the time you made the posting. But we did not make a posting because we thought you would see the data shortly after. We will check why the data is not there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-06-18 10:43:38
[2013-06-18 10:57:34] |
TY
[2013-06-19 00:49:41] |
The data should be available within about 15 minutes of it is not already.
[2013-06-19 13:59:46] |
TY
