Date/Time: Sun, 05 May 2024 17:39:09 +0000
Stop Loss Add Step feature
View Count: 794
[2015-08-18 17:46:06] |
bwalks123 - Posts: 122 |
Hello, I was curious if there was a way to add more than 2 steps for triggered offset stop loss orders? I want step 1 to move to break even once a particular price is reached, then step 2 to move up into profit once a higher price is reached and am curious if there is a way to add a step 3 and 4? Or is 2 all that is allowed? Also will these triggered stop loss orders work on fxcm trades if sierra chart is closed? Thanks |
[2015-08-18 18:32:58] |
This is not supported. Trailing stops will not work if Sierra Chart is not running. Sounds like you might be interested in the Triggered Trailing Stop order type: https://www.sierrachart.com/index.php?page=doc/doc_OrderTypes.html#TriggeredTrailingStop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 18:33:26
