Date/Time: Tue, 07 May 2024 23:18:23 +0000
Study Subgraphs Difference - Not recalculating
View Count: 1160
[2015-08-18 07:56:20] |
Dema - Posts: 42 |
Hi SC Team, I am having some problems with the Study Subgraphs Difference study not updating with new ticks. Chart A: 5 minute line chart, source is custom .scid binary write ~10 second intervals Chart B: 5 minute line chart, source is custom .scid binary write ~10 second intervals Chart C: 5 minute candle chart, source is AUDUSD (SC FXCM intraday). Note 1: On chart C I have two Study/Price Overlay studies, one referencing Chart A (last) and another referencing Chart B (last). Note 2: On chart C I also have a Study Subgraphs Difference study, to calculate the difference between the two Study/Price Overlay studies. The problem is that the Study Subgraphs Difference study is not updating in line with two Study/Price Overlay studies. The two Study/Price Overlay studies update in line with the Chart A and B last values. Also a forced recalculate does update the Study Subgraphs Difference study value, but this isn't practical in live trading. Thankyou. Screenshot attached Update: The difference study does update when the data has caught up to the current bar. Please consider this a low priority item. Date Time Of Last Edit: 2015-08-18 08:57:27
screenshot.PNG / V - Attached On 2015-08-18 08:13:44 UTC - Size: 44.47 KB - 279 views |
[2015-08-18 10:16:09] |
This documentation may be relevant to the problem: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyCalculationPrecedence Otherwise, there is nothing for us to do here and we will not to invest any time on this. However, refer to the Input Settings for the Study/Price Overlay study to make sure the Inputs are set so that the data being overlaid extends to the last bar in the chart always: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s118 The usual way to do this iis to set Fill Blanks with Last Value to Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 10:27:06
[2015-08-18 10:25:31] |
The prior post has been updated.
