Date/Time: Mon, 06 May 2024 21:38:55 +0000
New status bar
View Count: 814
[2015-08-18 07:55:48] |
EuropeanTrader - Posts: 290 |
Hi, is ther a way I can modify new status bar? I have many small charts on my screen and now if I click on one there is this "huge" status bar over that small window preventing me to see all bars on it, so I am not even seeing where my cursor is (behing status bar). It is very annoying. I understand you made the new status bar because of technical improvments but is there a way I can have it differently - make just one status bar for complete SC not by window, so I can put it somewhere that it will not be a distraction? Thank you |
[2015-08-18 10:34:20] |
You need to disable Global Settings >> Tool Settings >> Save Compact Tool Values Window Position for Each Chart.
