Date/Time: Sun, 19 May 2024 01:42:24 +0000
Forex Symbols
View Count: 865
[2015-08-17 21:33:06] |
User684905 - Posts: 2 |
I have tried to figure out how to pull up a FOREX chart with no success. I am looking to pull up USD/JPY. Any help with this would be appreciated. I know it is probably very simple, but I can not figure it out.
[2015-08-18 04:28:20] |
You need to use the Sierra Chart Forex Data Service: Sierra Chart Real Time and Historical Forex and CFD Data Service: Setup Instructions Also be sure to update the symbol settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 04:30:36
[2015-08-18 13:29:07] |
The problem is that I am trying to use my TD Ameritrade connection. If I try to use the FXCM connection, I get kicked off of real time information.
[2015-08-18 17:54:04] |
Update Sierra Chart to the latest prerelease with Help >> Download Prerelease. Here are instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate The latest release supports this: Added support to access SC Forex Data when using any of the other supported Data and Trading services. The symbols are listed in File >> Find Symbol under the categories CFD and Forex. This symbol listings may not be up-to-date until the end of the day on 2015-08-18.
The above is from the What is New page. We did update the symbol settings for TD Ameritrade at this time to include the Forex symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-19 06:11:01] |
tobi - Posts: 351 |
Will the SC Forex Data also be available within IB's dataservice?
[2015-08-19 06:41:59] |
Yes. This is now available in the latest prerelease.
[2015-08-19 07:22:49] |
tobi - Posts: 351 |
Just updated to newest prerelease (new spreadsheets) and also did Full Reset and Update From Server in Global Symbol Settings, but SC Forex Symbols not available (s. screenshot). Am I doning something wrong here?
Symbols.png / V - Attached On 2015-08-19 07:14:00 UTC - Size: 19.56 KB - 254 views |
[2015-08-19 07:31:13] |
Update the Symbol Settings. You will get them now. We had thought they were released but they were not.
