Date/Time: Thu, 16 May 2024 15:04:00 +0000
Compact tool value window
View Count: 873
[2015-08-17 19:29:24] |
SgtJ - Posts: 154 |
How do I add #trades to the CTVW? Tried this link but it doesn't seem to apply to the CTVW. Seems not all of the options work. https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingMainPriceGraphValuesVW sc ver 1282 Date Time Of Last Edit: 2015-08-17 19:29:42
[2015-08-20 03:48:34] |
We will add this.
[2015-08-21 16:23:34] |
SgtJ - Posts: 154 |
Is it possible to make the compact tvw work the way the old status bar did in the sense that when I click the chart to lock a fixed bar to get the stats the ctvw disappears, is it possible to have it always display. I don't want to keep the full tool values window open to achieve this effect. I would assume most people are using the ctvw and would benefit from the always displayed effect. ty
[2015-08-21 17:32:04] |
Yes. This capability will be added in the next few days.
