Date/Time: Fri, 26 Apr 2024 03:03:27 +0000
DMI histogram
View Count: 1995
[2013-06-12 18:03:03] |
TradingMarketProfile - Posts: 120 |
Hello, Is it possible to see the DMI or DMI +ADX in histogram, please Thanks |
[2013-06-12 18:10:47] |
Yes. This can be done. The histogram is a difference between DI + and DI -. Use the study Study Subgraphs Difference. Here is the documentation: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s185 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-12 18:35:00] |
ok thanks it's done but i can not changed colors like green for DI+ and red for DI- http://www.sierrachart.com/image.php?l=1371061741204.png |
[2013-06-12 19:17:50] |
Sawtooth - Posts: 3976 |
Set the Auto-Coloring to Based on +/-
[2013-06-12 19:35:33] |
ok it works thanks
