Date/Time: Tue, 07 May 2024 17:54:50 +0000
Plot a graph for forex
View Count: 728
[2015-08-17 15:42:01] |
User68117 - Posts: 64 |
Hello, I would please ask you to set it to my candles in a chart portrayed on 4 Decimal Places. In setting this chart I have. Values show me a jump of 4 decimal digits, but also draws a graph of the value, for example, 1.5674 and 1.5675. Comes this sort of set up? thank you Date Time Of Last Edit: 2015-08-17 15:42:58
Forex data settings.jpg / V - Attached On 2015-08-17 15:42:41 UTC - Size: 169.63 KB - 272 views Forex data.jpg / V - Attached On 2015-08-17 15:42:49 UTC - Size: 218.37 KB - 294 views |
[2015-08-17 17:07:23] |
We are not understanding this.
[2015-08-17 17:25:47] |
Actually, we see what you are referring to now. We recommend using this particular study (Round Price Bars to Tick Size): http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s308 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-17 17:26:19
[2015-08-17 17:26:02] |
Why candle depicts a space between 1.5674 and 1.5675? See attached screen.
[2015-08-17 17:26:52] |
See post #3 for the answer.
