Date/Time: Wed, 01 May 2024 22:17:48 +0000
VBP Study issue with Version 1282
View Count: 728
[2015-08-17 14:51:05] |
ZH Support - Posts: 19 |
Sierra, On the new version 1282 there is an issue with the VBP study. When I apply the study to the 30 min ES charts with a start time of 8:30 am central time and end time of 16:14:59 pm there is an issue with the study when I have the "Number Of periods back to reference" set to 1 and the Volume Graph Period type set to Multiple Profiles Fixed by Time. Please see the screen shots below and let me know what I need to correct on my end. Thank You Jake |
Study_window.png / V - Attached On 2015-08-17 14:50:36 UTC - Size: 80.07 KB - 275 views Attachment Deleted. |
[2015-08-17 17:35:12] |
Referencing a prior period with an incomplete day, is not always going to work well. If this worked in a previous version, it is because of enhancements in the newer versions to make this logic work better but it creates this new problem. Inherently this is complex. You need to really set the Session Times to cover the full 24 hours. We will think about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-17 17:35:43
