Date/Time: Mon, 06 May 2024 21:26:01 +0000
Use of package 5
View Count: 823
[2015-08-17 11:34:16] |
User83040 - Posts: 9 |
Hello, I have been paying package 5 of SierraChart for several months at AMP. Now I intend to open an account with Interactive Brokers to also trade stocks. May I in such a case use SC platform? Will my monthly payment of SC package 5 at AMP cover also connection to another broker? Thank you. |
[2015-08-17 16:39:56] |
For this you need to use your own direct Sierra Chart account and pay for it. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-17 16:40:37
[2015-08-18 09:54:11] |
OK,please would the following "new setup" work ? Existing setup: 1 copy of SC (package5) via trading service AMP, data from Rithmic. New setup: 2 copies of SC. First copy with Rithmic data would be Source copy, second copy on my own SC account would be Destination copy using Rithmic data and connected to trading service IB. Thanks |
[2015-08-18 10:14:38] |
This should work but if there are any problems with it, we do not provide support for this. However, here is the documentation for that: Using Multiple Data and Trading Services at the Same Time You really should use the Sierra Chart Exchange Data Feed for better data than Interactive Brokers: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
