Date/Time: Sun, 19 May 2024 03:48:18 +0000
Dll studies
View Count: 2200
[2015-08-17 10:59:30] |
User95457 - Posts: 19 |
I downloaded the new version but it didn't work wiith NinjaTrader Brokerage so I downloaded again version 1252 but I can't see some dll study I had on the chart anymore. How can I recover them?
[2015-08-17 13:00:46] |
In particolar there aren't all the user contributed studies, for example the VWAP with standard lines I used in my charts
[2015-08-17 14:44:08] |
WarEagle - Posts: 70 |
I am having this problem as well. I updated to the latest version (1282) and now get the message for a study I use quite a bit: Failed to get the Advanced Custom Study function address for scsf_PriceOverlay in SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. | 2015-08-17 08:19:09 * |
[2015-08-17 16:23:49] |
so I downloaded again version 1252 but I can't see some dll study I had on the chart anymore. How can I recover them? We need more information about this. Follow the instructions here to use an Advanced Custom Study:https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html At what point is there a problem? Please provide more details. Is there any error message given? In particolar there aren't all the user contributed studies, for example the VWAP with standard lines I used in my charts This is a problem. You will need the current version of Sierra Chart for this.Failed to get the Advanced Custom Study function address for scsf_PriceOverlay in SierraChartStudies.dll. Error: Windows error code 127: The specified procedure could not be found. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-17 16:27:08
[2015-08-18 14:05:19] |
This indicates the particular study you are using, has a new internal name and this is a study which is not listed in the main list of studies.
Ok thanks, what did you rename it to? I don't see anything similar. I want to take the high and low of the chart my DOM is created from and plot them on the DOM (on the left where the profile plots). I was using PriceOverlay for this and it worked perfectly. |
[2015-08-18 18:47:08] |
You can use the Daily OHLC study for this. To add that study to the Trade DOM select Chart >> Studies >> Add Custom Study >> Sierra Chart Custom Studies. Update: We just realized this might not work properly. You may need to use the Study/Price Overlay study instead. That can be added directly through Chart >> Studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-18 18:48:34
[2015-08-19 13:36:35] |
Thank you for your help but this study does not work for what I was using PriceOverlay for. This will only let me choose from the studies on the chart. I need the high and low. Is there any way to get the old one back? |
[2015-08-19 17:05:43] |
It sounds like you will need to put the Daily OHLC study on a chart of the same symbol and overlay that using the Study/Price Overlay study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-19 17:06:06
[2015-08-19 17:32:03] |
The problem is that this only gives me the daily high and low where I need the high and low for a smaller chart. In the meantime I found a solution in case someone else has this issue in the future. The "Overlay (Single Line)" indicator will let you select the high or low just as Price Overlay did. Thanks |
[2015-08-19 18:21:35] |
OK that was the actual study which had its internal name changed. We were trying to remember what it was. We did not know you needed a different high and low. We thought maybe you wanted to see the previous day's high and low. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-19 18:21:48
[2015-08-29 15:34:23] |
Problems solved. I found the study I was looking for in custom studies and modified some internal parameters in order to meet my previous settings. The only problem left is that Sierra Chart version 1282 doesn't run with a NinjaTrader Brokerage account. Does the latest release (v. 1289) solve this lack of connection?
[2015-08-29 21:10:41] |
You can use CQG with ninja trader brokerage. But you cannot use Rithmic with ninja trader brokerage.
