Date/Time: Thu, 02 May 2024 05:18:40 +0000
Auto Retracement - Backtesting
View Count: 2041
[2013-03-27 11:37:34] |
JohnnyT__ - Posts: 16 |
Hi I´m using the spreadsheet backttesting with the Auto Retracement study with a specific time period in minutes. All is good until i try to do a replay (accurate) backtesting and it doesn´t respect the time period assuming the inicial high/low and doesn´t RESET on the given period. Tried diferent periods (Day, diferent minutes...) and all options on the replay (For all charts... Skip empty periods) and also tried with low SPEED but nothing seems to work and it never resets the high/low values given periods... A little help here, please. Thanks in advance JT |
[2013-03-27 19:37:55] |
We do see a problem and it will be resolved in the next release.
[2013-03-27 21:59:03] |
Thanks. Appreciate it. Looking forward for the next release. JT |
