Date/Time: Sun, 28 Apr 2024 15:41:59 +0000
different color background
View Count: 1805
[2015-08-16 16:22:14] |
User52028 - Posts: 7 |
How can I change background color in one chart and keep white color background in other charts in the same chartbook?
[2015-08-17 05:49:59] |
tobi - Posts: 351 |
For the chart you want to change the background color, click on Chart >> Graphics Settings and uncheck Use Global Graphics Settings Instead Of These Settings. Then change the color items below according to you needs.
[2015-08-17 07:22:07] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
