Date/Time: Sun, 28 Apr 2024 16:32:46 +0000
Download New Version
View Count: 745
[2015-08-14 20:56:44] |
tellerbe - Posts: 109 |
I downloaded the new version. On my desktop,not the chart, is a chart looking thing that follows my cursor. It has the following in a vertical line. Y, Date, Open, High, Low, Last,Volume, Bid Vol, Ask Vol. I can't figure out how to remove it. T.Ellerbee |
[2015-08-14 21:17:35] |
Forget it. I lucked upon the solution. T.Ellerbee |
[2015-08-14 22:31:29] |
This is the Window >> Compact Tool Values Window. This is documented in post #2 here: New Control Bar to replace ToolBar and Status Bar You just need to uncheck this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
