Date/Time: Sat, 04 May 2024 10:56:51 +0000
HIDING Right Price Scale
View Count: 2066
[2015-08-14 16:17:33] |
AP - Posts: 117 |
Please - is there a way to hide the right price scale altogether and just have the chart displayed? Please.
[2015-08-14 17:40:02] |
Yes. This is Chart >> Chart Settings >> Advanced Settings >> Hide Values Scale.
[2023-03-25 06:51:08] |
User585104 - Posts: 115 |
Yeah that is perfect for this experiment. Is there a way to remove the current price while keeping the scale? Thanks |
[2023-03-27 14:14:53] |
John - SC Support - Posts: 31362 |
Disable the option for Graphics Setting >> Last Trade Price Box. When you select this option, you will see an "Enable" option with a checkmark next to it. Deselect the checkmark to disable the price box. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
