Date/Time: Tue, 27 Oct 2026 22:07:05 +0000
NYSE TICK down?
View Count: 1255
| [2015-08-14 13:35:07] |
| Cavalry3162 - Posts: 523 |
hello support, i do not get any NYSE-TICK data today, any issues? i am on sierrachart feed thanks, Andreas |
| [2015-08-14 17:22:59] |
Refer to this thread here: Announcement: NYSE TICK Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-08-14 17:30:16] |
thank you, any eta for the history? thanks, Andreas |
| [2015-08-14 17:32:06] |
We can fill in the missing data for the TICK-NYSE but there is not a practical solution to fill in the missing data for the other TICK market statistics symbols which were also affected.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-14 18:28:16
| [2015-08-14 18:01:03] |
| User791263 - Posts: 151 |
THANK YOU Sierra Tech Team. You got it FIXED. Problem was only because you are ALWAYS trying go IMPROVE. You all are STILL THE BEST. |
| [2015-08-14 18:23:39] |
Still, there were several serious failures this morning that led to the extended outage. We have also filled in the data now for the TICK-NYSE.
