Date/Time: Sat, 27 Apr 2024 11:49:49 +0000
Volume profile
View Count: 801
[2015-08-14 08:30:20] |
User832215 - Posts: 27 |
I have drawn multiple volume profile on my chart, 1 big and multiple smaller volume profile in the big one. My issue is that it's hard to select the right volume profile, for example when I want to change settings for a specific volume profile. When I try to select a smaller volume profile then sierra chart has a tendency to always select to bigger one. Is there a shortcut to make it easier to select a volume profile in the bigger one instead of trying to click 9989 times to select the right one.
[2015-08-14 18:02:27] |
What will help is to enable Global Settings >> Select Drawn Volume Profile by Outline Only
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-14 18:02:51
