Date/Time: Fri, 03 May 2024 12:10:49 +0000
Error with new version update
View Count: 712
[2015-08-14 07:23:33] |
EuropeanTrader - Posts: 290 |
Hello, I just updated to new version (new spreadsheets) since I was informed about it when starting up my SC. However, My settings have unexpectedly changed. Toolbar icons have gotten really big and a toolbar where OHLC numbers were shown dissapeared and now I have this "info" window on each window I click at. I dont like that, I want to use my old settings. Thank you |
[2015-08-14 07:39:37] |
My settings have unexpectedly changed What settings are these? There should be no change other than the items you describe.For the other described issues, refer to the first 2 posts here: New Control Bar to replace ToolBar and Status Bar They contain all the information you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-14 07:40:04
