Date/Time: Sat, 04 May 2024 22:39:07 +0000
volume rate of change
View Count: 1454
[2015-08-14 05:24:50] |
User898014 - Posts: 4 |
I used in MC this indicator. For me is very helping for see reverses. Any idea to get ? os some similar ? |
[2015-08-14 08:25:22] |
User60518 - Posts: 106 |
The rate of change study looks like what you are after: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s37 |
[2015-08-15 22:39:05] |
What you need to do is add the Volume study to the chart and add the Rate of Change study and base the Rate of Change study on the Volume study Here is the relevant documentation: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s37 http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#BasedOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
