Date/Time: Sun, 05 May 2024 16:06:48 +0000
How do I get The Region data line to transfer to Study/Price overlay study.
View Count: 965
[2015-08-14 01:46:21] |
dd45 - Posts: 41 |
I want the custom name and the removal of all the extra data points to carry over to the overlayed chart. on the single chart of the XLK it shows up correct but not when overlayed to the "Financials" chart
sierra.jpg / V - Attached On 2015-08-14 01:45:03 UTC - Size: 58.11 KB - 308 views |
[2015-08-14 13:43:04] |
dd45 - Posts: 41 |
any help on this?
[2015-08-14 18:52:19] |
The custom Title Bar Name does not copy over with the Study/Price Overlay Study. This is not supported. For the other question, refer to the documentation here for this: https://www.sierrachart.com/index.php?page=doc/helpdetails67.html#HidingStudyNamesValuesVWRDL What do you mean by this: on the single chart of the XLK it shows up correct but not when overlayed to the "Financials" chart
Please be specific. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-14 20:35:20] |
dd45 - Posts: 41 |
I attached another picture, In the XLK Chart I did Global Settings --> Custom Chart header, and removed everything except the Hi and Lo. when that chart is then study/price overlayed onto the XLF chart, I still have all those values that i removed from the XLK chart. does this clarify what im trying to do? id like to get rid of all that extra data in the header for the overlayed chart. |
[2015-08-17 15:03:57] |
dd45 - Posts: 41 |
any help with this please? im trying hard to figure this out on my own but cant get it.
[2015-08-17 16:55:10] |
We need some time to look into this. We will have an answer around the end of the day.
[2015-08-18 11:40:19] |
What you want to do in post #4 is not supported when overlaying the main price graph from another chart. We are working on adding this capability but it is not going to be ready until the end of next week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-18 12:42:23] |
dd45 - Posts: 41 |
thank you i will check back.
[2015-08-25 15:14:25] |
dd45 - Posts: 41 |
Is this ready yet?
[2015-08-25 18:06:09] |
No not yet. We have a lot of other higher priorities at this time. We may not get to this for a while yet. We should not have given a time previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
