Date/Time: Wed, 08 May 2024 02:34:38 +0000
markers in expansion area moving with new data
View Count: 788
[2015-08-13 20:31:59] |
User788947 - Posts: 7 |
I have been using the marker tool to identify future targets in the expansion area. Occasionally when I open Sierra Chart the next time, all the markers are moved to the left, many of them slammed into a vertical line at the opening bar of the day. Usually a problem on the intraday charts, not historical. Help?
[2015-08-13 21:10:39] |
This kind of problem is documented here: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html We assume the chart bars are not based on a fixed amount of time? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-13 21:29:05] |
The charts were hour, 10min, and 1min. Each was separate, I did not change the timeframe within a chart.
[2015-08-13 21:33:11] |
There is a definite reason why this is happening. What Date-Time was one of the markers placed at? What is the Date-Time of the bar or column they moved to? And what is the Date-Time of the column after the marker, when you notice it move. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
