Date/Time: Sat, 04 May 2024 11:23:59 +0000
Price on chart to display as Percentage of daily move
View Count: 859
[2015-08-13 20:28:42] |
dd45 - Posts: 41 |
On any of these charts where is the setting that allows me to change it from the actual value of the index or stock to the percentage it is up on the day. these are for my intraday charts. Thanks.
[2015-08-14 19:08:57] |
For this you need to use the Percent Change Since Open study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s325 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-14 19:45:02] |
infpz - Posts: 826 |
pz@infinityfutures.com
