Date/Time: Wed, 08 May 2024 00:54:02 +0000
Vertical Line Tool - adding Text issue
View Count: 788
[2015-08-13 20:17:15] |
sampater - Posts: 243 |
In the Vertical Line Tool do not display any Text until there is checked the Date or the Time option. Is it correct? |
[2015-08-13 20:19:14] |
Yes. This makes sense. What is the purpose of the question? We would think this is obvious.
[2015-08-13 20:39:28] |
In the Vertical Line Tool i usually want to add only a text without any time or date. Can you add this option? |
[2015-08-13 21:04:59] |
OK we understand now. This will be solved in the next release.
