Date/Time: Tue, 07 May 2024 12:40:13 +0000
Options-Trading with CQG
View Count: 2283
[2015-08-12 13:20:10] |
BrMa - Posts: 77 |
Dear ladies and gentlemen, I created a quote board for the PUT-Options on different prices for DAX options. (Please see the link below attached) http://www.sierrachart.com/image.php?l=14393849906.png I do have two issues I cannot resolve by myself: 1) Altghough the documentation says that intraday charts on options are supported I cannot get any chart displayed - it stays empty 2) I would like to be in the position to quickly trade options out of the quote board. The only possibility I found up to now is, to open a Trading-DOM pressing <Ctrl><T>. But it's not very convenient as you need to enter the symbol every time... what is quite extensiveley long with option-codes at CQG. Is there any way I can quickly arrange a trading DOM for it? Any help is highly appreciated! Regards, Markus |
[2015-08-13 04:39:08] |
1. At this time historical data is not supported from CQG for these particular symbols but should be within the next month. 2. What we recommend you do is use the Chart Linking feature with Quote Boards which also works with Trade DOMs. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_GettingQuotes.html#ChangingSymbolOfChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-13 04:39:45
