Date/Time: Thu, 02 May 2024 16:53:39 +0000
[User Discussion] - sc.UseTool question How to delete Muliple drawings that all originate at the same index
View Count: 837
[2015-08-11 06:15:44] |
enemyspy - Posts: 304 |
I am aware to use this to delete a specific line number: DeleteACSChartDrawing(int ChartNumber, int Tool, int LineNumber);
However I am in a situation where Multiple drawings exist at one index and once a certain condition is met they all need to be removed.Is there a way to either use TOOL_DELETE_CHARTDRAWING where the line number is greater than or less than a certain value to remove all above that value? Or some way to use the TOOL_DELETE_ALL but only for drawings originating at a specified index? or some other way to do this? Date Time Of Last Edit: 2015-08-11 06:16:42
[2015-08-11 06:18:52] |
Also each drawing at a particular index cannot share the same ID as I am using the UTAM_ADD_OR_ADJUST method. Any help is greatly appreciated.
[2015-08-11 17:45:47] |
I guess that means no?
