Date/Time: Mon, 29 Apr 2024 00:31:36 +0000
ADDING A GROUP OF STUDIES TO THE TOOL BAR, IS IT POSSIBLE TO DO, THEN HOW DO YOU DO IT?
View Count: 739
[2015-08-10 20:45:42] |
blknsxy - Posts: 29 |
I want to add a Study that I have saved in the Title Bar >> Analysis, to a Tool Bar. This would enable study selection and or on/off of a Study without having to select it from Title Bar >> Analysis? Thanks |
[2015-08-11 05:30:31] |
No, this is not supported.
