Date/Time: Fri, 03 May 2024 00:07:20 +0000
No continuous contracts for AEX futures
View Count: 908
[2015-08-10 17:48:18] |
phililppm - Posts: 10 |
Dear Sierra Chart Team, The continuous contract feature doesn't work for AEX futures (symbol F.US.FTIQ15 in the Sierra Chart data feed), see the attached message log. Other symbols on the same exchange, such as the CAC40 (symbol F.US.PILQ15) work fine. Please advise. Thank you in advance & best regards Philipp |
message_log.txt - Attached On 2015-08-10 17:47:46 UTC - Size: 1.09 KB - 333 views |
[2015-08-10 18:03:11] |
The Symbol Settings for the symbol have been updated to support Continuous Futures Contract charts. Update the symbol settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps After that is done go to the chart and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-10 18:44:22] |
Thank you, that worked!
